Keyframe Interpolation troubles
Michael Strassburger
on May 25, 2011 at 6:00:17 pm
I'm using the Ripple effect and I'm putting keyframes on the wave speed property. I'd like the keyframe interpolation to be bezier, but it only allows hold. Do some properties not allow bezier or others? I can't figure out how to change it.
Dave LaRonde
Re: Keyframe Interpolation troubles
on May 25, 2011 at 6:12:39 pm
[Michael Strassburger] "Do some properties not allow bezier or others?"
That's correct. Some properties must be changed in integer increments. It depends on the property. For example, you can keyframe the contents of a text layer, but you'll make Hold keyframes.
Dave LaRonde
Sr. Promotion Producer
on May 25, 2011 at 6:31:04 pm
Thank you, Dave! I am moving on and dealing with it.
Julius Acena
on May 30, 2011 at 9:06:47 am
Maybe you can try pre-composing your ripple comp and time remap it?
