Flash (SWF file) audio does not import into CS3
Michael Urbansky
on Mar 23, 2011 at 11:58:17 pm
Audio from a swf video file (Flash file) does not import into CS3. Video comes in fine. How do I fix this? Using a PowerPC Mac not an Intel Mac. OS 10.5.8
Todd Kopriva
Re: Flash (SWF file) audio does not import into CS3
on Mar 24, 2011 at 1:35:20 am
from After Effects Help:
"SWF (continuously rasterized)
Note: SWF files are imported with an alpha channel. Audio is not retained. Interactive content and scripted animation are not retained. Animation defined by keyframes in the main, top-level movie is retained."
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Michael Urbansky
on Mar 24, 2011 at 3:06:52 am
Thank you for confirming that audio is not retained.
Workflow question:
So if I want to edit a mov with audio with a swf with audio together in the timeline (one cut only, no fades, nothing fancy) do I extract the audio from the source swf, convert that audio to something AE CS3 can import and sync it up in the timeline?
Todd Kopriva
on Mar 24, 2011 at 4:44:38 am
Yes.
Michael Urbansky
on Mar 24, 2011 at 2:23:11 pm
Now there's another problem I think I've seem on these forums and am working on. The audio doesn't sync to the video.
Michael Urbansky
on Mar 24, 2011 at 5:27:54 pm
Just occurred to me that the short audio could be a good indicator of the length and pacing the Flash animator expected. So I should time remap to video, get client approval and move on. : )
