Upgrade advice for a low-end system
Fredrik Viklund
on Mar 23, 2011 at 12:33:10 pm
I've just started taking a course to learn more about After Effects CS5. I'm working in modest resolutions.
I want to upgrade my system but I have a very limited budget, around USD 200-300.
Current system:
CPU - Athlon X2 4850e @ 2.5GHz
RAM - 4 GB DDR2 (2+2), 800 MHz
Motherboard - Asus M3N78-EM, AM2+, nVidia 8300 chipset
Graphics - motherboard nVidia 8300, using system RAM
Disk: 750 GB system & apps + 1 TB for user files
So it's not very impressive :-)
I am choosing between:
Alt 1. Upgrade CPU and RAM
- Upgrade CPU to Phenom X4 940 @ 3 GHz
- Add 4GB RAM to a total of 8 GB (motherboard maximum)
Alt 2. Upgrade GPU
- Get a GeForce card and use the hack to enable GPU acceleration
Unfortunately I can't afford to do both at this time
* What's the preferred upgrade route?
* What kind of performance increase can I expect?
* What graphics card would give me the most bang for the buck?
Many thanks,
/Fredrik
Michael Szalapski
Re: Upgrade advice for a low-end system
on Mar 23, 2011 at 1:13:53 pm
There will be no performance increase for AE with a graphics card upgrade unless you're using a plugin that takes advantage of it. (There aren't many that do.)
Definitely max out your RAM. AE will want as much of that as you can give it and a faster processor wouldn't hurt.
It's hard to give any sort of predictions for speed increases since there are so many variables at play.
This thread [link] on the Adobe forums should give you an idea of what settings you should do for your RAM usage and whether you should use multiprocessing.
- The Great Szalam
Fredrik Viklund
on Mar 24, 2011 at 12:04:31 pm
OK, thanks for a quick and useful reply. I'm going to get the RAM and the Phenom is a bargain so I'll have that too.
/Fredrik
