Quick Rending Question (Animation not showing up)
Randy Illum
on Mar 15, 2011 at 1:37:59 am
Hey Everyone,
I am working on a project where I have 22 layers from photoshop that make up the composition. I have made keyframes so when the opacity of the layer changes it creates a keyframe over 30 seconds. When I manually drag the time indicator i can see the animation (the opacity of the layers changes). But when I use the space bar to preview nothing happens. I have also noticed when using the space bar or a RAM preview (which does not work) the yellow triangle on top of the time indicator does not move. I have also rendered out the animation and the opacity changes are still now showing up. Any suggestions?
Thanks.
Michael Szalapski
Re: Quick Rending Question (Animation not showing up)
on Mar 15, 2011 at 1:24:11 pm
You RAM Preview by pressing 0 on your number pad and it doesn't show any change in opacity, but moving your time indicator does? (I'm trying to make sure I'm understanding your issue.)
Could you provide a screenshot of your timeline with opacity twirled down and/or upload your project file?
- The Great Szalam
SPACE MAN
on Mar 15, 2011 at 2:14:44 pm
SPACEMAN wonders if there is a project depth issue here?
SPACEMAN needs spaceship parts, not expressions...
