AE CS5 won't import .mov files!!!
Brandon Daniel
on Mar 10, 2011 at 1:45:01 pm
Hi guys. This may be a newbie issue but whenever I try to import .mov files into After Effects CS5 I get an error message stating "this 'MooV' file is damaged or unsupported". This has been going on since I upgraded to CS5. Is there a fix for this at all? Thanks
Dave LaRonde
Re: AE CS5 won't import .mov files!!!
on Mar 10, 2011 at 5:01:47 pm
You may need to update to the more recent AE version, 10.0.1 (or higher). Look under Help>Update.
If you're running Quicktime X, you will want to UN-install it, then install the latest version of QT 7. I'd get QT Pro: the best 35 bucks you'll spend in many a moon.
Dave LaRonde
Sr. Promotion Producer
Todd Kopriva
on Mar 10, 2011 at 5:27:06 pm
Here are some troubleshooting suggestions for QuickTime issues:
http://blogs.adobe.com/toddkopriva/2011/02/troubleshooting-quicktime-errors...
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
