Lengthening comps in a template
Sergio Manente
on Feb 17, 2011 at 11:31:02 pm
been working on a project in which I need to lengthen some comps within comps, My second one is lengthier than the on in the template so when I lengthen it I get a slow motion stretch and slow speech... any ideas on what I'm doing wrong?
Dave LaRonde
Re: Lengthening comps in a template
on Feb 17, 2011 at 11:39:27 pm
How long have you been using After Effects?
If you say "not very long", you should know that it is a very complicated program, and you need to know the basics. It's almost impossible to get anything done, even with the help of a template you bought, if you don't have some knowledge of AE basics.
This is an excellent place to get that knowledge:
Dave LaRonde
Sr. Promotion Producer
Rob White
on Feb 19, 2011 at 3:56:33 am
Can you create a new pre-comp from the layers inside the comp you're trying to lengthen, and extend those layers? Or just extend the layers in the first place?
I don't really understand the problem you're having because I've got no reference to the "template" you speak of. So this may be no help at all.
I hope you figure it out.
© 2018 All Rights Reserved
