Change FPS rate without changing speed
Joaquín Gallo
on Jun 23, 2014 at 6:34:11 am
Hi!
I have this problem: I filmed a video in 50fps but i need it in 29,97. ¿Why i filming in 50fps? Because in canon i cant film in 29,97 and i need edit two videos in the same comp.
It's possible change 50fps to 29,97 without change speed?
Thanks a lot!
Bhavesh Jadav
Re: Change FPS rate without changing speed
on Jun 23, 2014 at 7:01:29 am
Hi Joaquin,
Import your footage in your project panel.
Right click on your footage>Interpret footage>Main.
There you can change your frame rate to whatever you want.
Joaquín Gallo
on Jun 23, 2014 at 7:16:06 am
Thanks Bhavesh for the answer.. I do it, but that change the duration of the video.
Bhavesh Jadav
on Jun 23, 2014 at 10:14:37 am
Hi Joaquin,
Try this, Drop your 50 fps footage in new comp.
Then make a new comp of frame rate 29.97 fps.
In that 29.97 fps comp add your 50 fps footage comp(not the real footage). This should work fine.
Joaquín Gallo
on Jun 23, 2014 at 12:55:51 pm
Works, Thanks a lot!! SOLVED!
Todd Kopriva
on Jun 23, 2014 at 7:01:01 am
Just interpret your footage as the frame rate in which you shot it and create a composition at the frame rate that you want.
Frame blending can take care of interpolated frames.
Learn more here:
https://www.video2brain.com/en/lessons/frame-rates
After Effects team blog
