Camera and object position problems.
Damian Smolinski
on Jan 20, 2011 at 3:09:15 pm
Hi!
Thank You for a very good forum.
I am quite new to After Effects, so I have a problem.
I´ve made a animation with SureTarget, a camera jumping from a text to a text, and so on.
No I want to add another text, for the camera to jump to.
So, i´ve done the process, but when I want to position the object, in order to make it appear in the middle of the screen, the camera moves together with the object, which make the other object/text to apperar somewhere else. This doesent happen when I try to move the other text object, the camera is seperated from the object.
This is killing my friends...
Anyone?
Dave LaRonde
Re: Camera and object position problems.
on Jan 20, 2011 at 4:31:45 pm
I don't mess around with Andrew Kramer's stuff -- they won't let me at work, y'know -- but it sounds like it's a simple matter of removing this SureTarget thingy from your comp, adding the additional text layer or whatever, and then reapplying Sure Target.
Dave LaRonde
Sr. Promotion Producer
Damian Smolinski
on Jan 21, 2011 at 8:15:35 am
Thanks Dave for answering.
I´ll give it a try!
