broadcast color safe
Ryan Santos
on Jan 5, 2011 at 10:42:06 am
If all I need is to make video broadcast color safe, do i need to have a calibrated monitor or will the scopes in Color Finesse suffice?
If I apply the Broadcast Colors effect to a footage, does that automatically make the footage broadcast color safe? Thanks and God bless.
Michael Szalapski
Re: broadcast color safe
on Jan 5, 2011 at 2:29:24 pm
As I understand it, pretty much yes to both.
You can use the scopes in Color Finesse to see what's outside the color range and to correct for it, but I feel you'll get better color if you can preview it on a broadcast monitor. At least you'll be able to see what you're doing.
Also, the Broadcast Colors filter does make it broadcast legal, you'd probably be better off doing it in Color Finesse though. You can make colors broadcast legal by applying a levels effect too. (input sliders to 235 and 16) :) but again, you'd get better quality fiddling with the colors manually in Color Finesse.
- The Great Szalam
Dave LaRonde
on Jan 5, 2011 at 4:22:40 pm
I have to disagree with Michael on one point.
Broadcast Colors is just about one of the most useless effects ever in AE; I stopped using it in AE 4.1. The reason: it takes a sledgehammer approach to fixing colors; it modifies EVERY color. It's like turning down the color saturation knob on an old TV set.
I would MUCH rather look at the scopes in Color Finesse, find the offending color, then fix that color and that color ALONE. The rest of the shot still looks nice and colorful.
Yes, it takes more time that way. No, it isn't automatic, nor fast 'n easy. But the result is worth it for me.
Dave LaRonde
Sr. Promotion Producer
Todd Kopriva
on Jan 5, 2011 at 5:44:06 pm
See this page. It gives tips and instructions for various methods.
One method is to use the Broadcast Colors effect, but not to automatically make the changes for you. Rather, you can use it to identify the areas that need adjustment so that you can make the adjustments yourself.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
Michael Szalapski
on Jan 5, 2011 at 6:00:33 pm
You're not disagreeing with me Dave, you're merely clarifying what I said. :)
- The Great Szalam
Chris Wright
on Jan 5, 2011 at 10:34:00 pm
color finesse's smart limiter is the simplest way because it smoothes the luma and chroma transition automatically instead of lopping it off.
http://technicolorsoftware.hostzi.com/
Ryan Santos
on Jan 6, 2011 at 12:19:32 am
Thanks guys for your answers. Really very helpful. God bless.
