Imported WMV files blurred at some comp sizes
Joshua Olsen
on Dec 16, 2010 at 8:54:14 pm
Hi everybody,
I've got a problem with imported WMV files appearing soft at some comp sizes while the same video appears crisp at other comp sizes.
Here are some quick stats on what I'm using:
- After Effects CS4
- Windows XP Professional
- Apple QuickTime 7 Pro
- I work in the e-learning industry and use 'non-conventional' video frame sizes
And some quick stats on the WMV file giving me issues:
- is a screen capture of a web page being used
- CODEC: Windows Media Video 9 Screen (MSS2)
- resolution: 1016 x 705 px
- frame rate: 5 fps
- millions of colors
I'm targeting a resolution of 668 x 500 px for the final rendered file so I've set up an AE comp to those dimensions with square pixels and at 5 fps.
When I drag the imported WMV onto the comp's timeline there is a slight blur to the footage.
When I adjust the comp's resolution from 668 x 500 px to 1016 x 705 px that slight blur is gone!
I'm really struggling to understand what could be causing this blur as I must have the final videos rendered out to 668 x 500 px.
Any help or insight into this problem would be greatly appreciated.
Merry xmas,
Josh.
Dave LaRonde
Re: Imported WMV files blurred at some comp sizes
on Dec 16, 2010 at 9:43:47 pm
Recording in Windows Media is a VERY BAD choice for use in AE 9. A very bad choice indeed. Can you either re-record it or convert it to a different kind of file, like a lossless AVI?
Dave LaRonde
Sr. Promotion Producer
Joshua Olsen
on Dec 16, 2010 at 10:58:53 pm
Hi Dave,
Thanks for your response.
I'll give that a go and post back my findings for the community.
I'm very cautious about using anything Windows Media in general. Thanks for the lossless AVI idea.
Josh.
