Write-on Effect with straight edge?
steve roberts
on Nov 23, 2010 at 5:41:16 pm
Hi There,
I'm trying to get a thick multi-colored (rainbow-like) curvy line to "draw itself in" in AE. I created the line using a custom brush in Illustrator, and then brought it into AE
I can use the Write-on effect, but that always gives me a rounded edge. I want to straight edge.
In a perfect world, i could import my custom brush into AE and then use the Stroke effect to make it "draw" around the screen. Is this possible?
Dave LaRonde
Re: Write-on Effect with straight edge?
on Nov 23, 2010 at 5:49:51 pm
Sadly, AE doesn't allow you to use custom brushes. If you look in the Paint effect, you may find a brush setting that's close, and that you can use with brush position information from Write-On.
Dave LaRonde
Sr. Promotion Producer
steve roberts
on Nov 23, 2010 at 6:21:06 pm
OK Thanks much! So what do you recommend for "drawing on a curvy shape" . If I use the write-on effect, i get a rounded edge.
if i use a mask, then getting a smooth animation is difficult.
Dave LaRonde
on Nov 23, 2010 at 6:47:27 pm
Paste the Write-On brush position data into the Paint brush position data; I haven't personally tried it, but I think it'll work.
Dave LaRonde
Todd Kopriva
on Nov 24, 2010 at 6:37:31 am
If you use a shape layer for this, you can set the end of the stroke to use a butt cap.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
