MultipleSound Files. Not Good?
Aharon Charnov
on Nov 21, 2010 at 11:08:17 pm
I know AE is not an editing program but I am doing some effects to specific sounds that are independent of my dialogue track. When I ram preview my movie I hear the dialogue and see the visuals. But the minute I add an additional .aif file to the comp, I lose my dialogue but I do hear the sound effect. CAN AE not do more that one sound file in a comp? IU really need to stay flexible and don't want to merge all my sound yet.
Is there a way to hear my dialogue and SFX at the same time during the same ram-preview?
Aharon
Dave LaRonde
Re: MultipleSound Files. Not Good?
on Nov 22, 2010 at 3:48:15 am
If you add the audio file to a comp, you should hear BOTH the original audio and the sound file.
But here's the fundamental question: how well do you know After Effects? If you think you're just going to do a couple of gee-whiz things in the application, you're sadly mistaken. This is one of these "learn to walk before you run" pieces of software.
For the AE novice, I heartily recommend the following:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.h...
...and if you ARE and after effects novice, you really do need it. There are other fine training tools I can recommend... but not until I've had a look at them myself.
Dave LaRonde
Sr. Promotion Producer
Aharon Charnov
on Nov 22, 2010 at 6:11:49 am
Dave:
Thanks for the input. Yes, if I add some sounds to a comp I SHOULD hear both sounds. But I'm not. I have Audio on and yet if I have more than one .aif in the comp (even if one is pre-comped) I cannot hear audio at all when I do any sort of previewing. When I render out a movie, the sound does carry over, so it's not completely broken. I have never had this happen before. Still trying to figure it out. As I said I made sure Audio was on....
I opened a new project and did some tests. They all worked so I am really at a loss. Could it be the size of the .aif? The larger one is really quite big although I am previewing only sections as I go through my work area in small increments... As I said, I am a bit stumped.
BTW thanks for the link. Sooner or later I read everything.
Aharon
Dave LaRonde
on Nov 22, 2010 at 4:43:22 pm
Here's a possibility: you haven't updated AE 10 to AE 10.0.1 with the free download from Adobe. This free update fixes a lot of AE weirdness, including AIFF weirdness.
Prior to version 10, AE never had problems with aiff files. Go figure. Happily, the update fixes it.
Dave LaRonde
