Transfer settings to a different computer?
Jeff Gandillon
on Nov 4, 2010 at 4:09:46 pm
I have 2 windows XP machines with After Effects 8 (CS3) on them and I want all the export settings and other general settings to match. Is there a trick to accomplishing this or do I need to do it manually?
jeff g
Jeff Gandillon
Re: Transfer settings to a different computer?
on Nov 4, 2010 at 9:51:12 pm
After looking around some more I realized the answer to part of my question was pretty obvious, so I figured I'd post it here in response to myself just in case someone else searches the forums with a similar question.
To transfer Render Settings and Output Modules it is as simple as going to Edit>Templates>Render Settings.../Output Module... and choosing "Save All..." to save a file with all your settings that can then be loaded, using the "Load..." button in the same place, on another machine.
Still haven't found a way to transfer "Preferences," but those are probably best set up on a machine-specific basis anyway.
jeff g
