displaying audio waveform effect on a mask
Terry Nauheim
on Oct 19, 2010 at 3:57:05 pm
I am assigning hand-drawn masks the audio waveform effect through the use of sounds in my comp. In some cases, the waveform does not fill the entire mask. For example, for a larger circle, it will only complete 2/3 of the circle. Is there a way to extend the display of the waveform?
Thank you,
Terry
running
AE CS3
IMac G5
Version 10.5.8
Processor 2.66 GHz Intel Core 2 Duo
Memory 4 GB 1067 MHz DDR3
Dave LaRonde
Re: displaying audio waveform effect on a mask
on Oct 19, 2010 at 6:21:18 pm
It's been years wince I used Audio Waveform. Doesn't the effect have a setting for percentage of layer to use, or something like that? Just twirl down all those settings and sniff around. I bet you find what you want.
Dave LaRonde
Sr. Promotion Producer
