Replacing footage in a template layer
gary woloszyn
on Aug 23, 2014 at 6:21:35 pm
I use Motion so I am a bit of a newbie to After Effects...
I want to reuse a complex scene with camera movement, lights, keyframes, etc. from a template. Then I want to change the image in that scene.
Do I make a new layer, copy and paste the old layer, then replace the footage using ALT+drag?
Thanks much
Hannes Andersson Donuan
Re: Replacing footage in a template layer
on Aug 24, 2014 at 3:52:03 pm
if you in "project" rightclick on the footage you want to change you can choose "replace" and select the file you want
Donuan
Digital Artist / Film Maker / VJ / Animator
http://donuan.tv
Dave LaRonde
on Aug 26, 2014 at 12:59:28 am
Since you're new, duplicate the layer you want to replace. Then you can highlight the original layer, and use Alt-Drag. Works great.
If it's right, you can delete the duplicated layer. If you messed up, you still have the duplicated layer to try again.
Dave LaRonde
Promotion Producer
