Resize composition to size of masked footage
Stepan Boltalin
on Sep 22, 2010 at 12:36:38 am
Hello,
This may seem as a dumb question.. But I've been stumbling on it for two hours already and googling doesn't help.
So I have a footage, I want to resize. I draw a mask.
I want a new composition exactly the size of that mask..
I don't care if I have to render the thing first.
But the best I cold get is the same footage, but with a huge black masked-out areas..
Advices would be reeeally appreciated.
Need this ASAP, really..
Drew Pertl
Re: Resize composition to size of masked footage
on Sep 22, 2010 at 4:04:55 am
Are you simply trying to resize using a mask? Could you possibly try resizing without the mask to get the same effect? If you provide some more details on what your attempting, I could probably give you a solution and/or workaround.
Drew Pertl
http://www.DrewPertl.com
Dave LaRonde
on Sep 22, 2010 at 3:32:29 pm
In your comp, mask the layer as desired. Scale up the layer until you don't see the edges of the mask any more.
Know that scaling up a layer too much results in the footage looking soft.
Dave LaRonde
Sr. Promotion Producer
