Linear Wipe
conor Dalrymple
Linear Wipe
on Sep 7, 2010 at 8:15:34 pm
Ok ill try explain what I want to do here. I want to make a linear wipe sit at 50% transition, lock at 50% ( half way down the stage) then I simply want to move objects position below the wipe and the wipe will stay at 50. whenever i put a liniear wipe on an object it moves with the object I dont want it to! hope someone understands this jibber. thanks
Todd Kopriva
Re: Linear Wipe
on Sep 8, 2010 at 6:15:17 am
You could put the wipe and the object that you want to move on different layers.
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
