reposition footage with keyframes?
jason zaloga
on Jul 21, 2010 at 6:35:28 am
can you reposition footage and it's motion path without disturbing the positional keyframes.
or do you just move the footage and re-do the keyframes.
Chris Kelley
Re: reposition footage with keyframes?
on Jul 21, 2010 at 7:09:04 am
The easiest way would be to parent your layer to a null, and then move the null. Your relative motion path for the original layer will remain unchanged when you move around the null object.
Read more about parent and child layers here:
http://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906...
http://chriskelley.tv/
http://themographblog.com
Michael Szalapski
on Jul 21, 2010 at 1:18:10 pm
The null plan is the best one. But just to show that there is more than one way to skin a cat:
With your current time indicator on a position keyframe, you can click on the position property to select all the position keyframes and then scrub the position values. All the keyframes will adjust.
A third way:
Change the anchor point's position.
- The Great Szalam
Dave LaRonde
on Jul 21, 2010 at 2:52:20 pm
[Michael Szalapski] "...there is more than one way to skin a cat:"
....and here's yet another way to skin this particular cat. Do like Michael says: put the timeline cursor on a keyframe & highlight the position property. Now use the arrow keys to move the layer. The entire motion path moves as you hit the keys. Works with the x10 keystroke combo, too.
Dave LaRonde
Sr. Promotion Producer
jason zaloga
on Jul 21, 2010 at 3:07:04 pm
thanks guys.
Michael Szalapski
on Jul 21, 2010 at 5:43:49 pm
You could also add a couple slider effects to your layer and put an expression on the position with the two sliders as variables then add those variables to the x and y positions. (Add another slider for z position.
:D
- The Great Szalam
