what I need to improve?
Gerardo Flores
on Jul 16, 2010 at 5:58:48 pm
Hello Guys
I have receive here a lot of good advice for improve my knowledge in AE.
Im using now a MAC PRO 3,1
2x2.8 Ghz quad core
4 giga ram
AE CS4
and the particle metrix eff from noise industries.
Im using for my compositions very big pictures ( 5685 × 1887 ) and while this tricks help me :
-turn off open GL
-not use multiprocessing
-save the video in other hard disk ( I do it sometimes in a external one )
-Activated AE's "Secret Preference" to purge cache every 20 frames (sometimes even to 1)
- and many other..
Im not able to render some compositions
Is there something that I need to improve in my equipment ?
please tell me what...
or I must just find the
right way to render the compositions
if that is the case ? what else can be the problem?
one more thank you a lot for your help
Best regards
Gerard.
learning after effects
Dave LaRonde
Re: what I need to improve?
on Jul 16, 2010 at 7:42:55 pm
The one thing you can do is get more RAM. You don't have very much at all. Walter Soyka, who makes really big AE animations for multi-screen, has 32 GB on his Mac Pro.
If you really want to reduce the problems of not being able to use big layers, you should get AE 10 (CS5). It will use all the RAM you can put on your machine, and big layer problems almost never happen.
Dave LaRonde
Sr. Promotion Producer
keith mcgregor
on Jul 26, 2010 at 7:57:32 pm
If you don't need them that big you would do well to reduce the size before you bring it in and it won't take so much ram just to read the image.
-Keith
Reality? What did you make it?
Gerardo Flores
on Jul 27, 2010 at 6:23:44 am
this one is a nice tip thank both of you
