CamStudio pipeline into After Effects CS4
Jesse Skellington
on Jul 10, 2010 at 6:44:27 am
Hi All,
I have found this CamStudio pipeline into After Effects CS4 to be working great so far. If anyone has other useful tip please jump right in :-)
Step 1
The version I use is Camstudio is 2.0. (http://CamStudio.org)
---* The codec was:
---* "CamStudio Lossless Codec v1.4" or "ffdshow Video Codec".
The setting are:
---* Set Key Frames Every: 120
---* Capture Frames Every: 33
---* Playback Rate: 30
Step 2
Then to convert the video I use "FLV to AVI MPEG WMV 3GP MP4 iPod" Converter it can be found here: (http://www.aone-soft.com//flv_to_avi_mpeg_wmv_3gp_mp4_ipod_converter.htm)
---* The version I use is "FLV to AVI MPEG WMV 3GP MP4 iPod" Converter is 5.0.0526
The settings are:
---* Output Format: H264 - AVC MPEG-4 Format (*.mp4)
---* Video Quality: Superb
---* Video Size: Keep Original Size
Step 3
In After Effects CS4 I render out to:
---* Format: QuickTime Movie (I use the defalts)
---* Note: This will make a Large GB Sized file but this is how I keep the pixel quality perfect.
Step 4
Next I use Adobe Media Encoder CS4
* Format: FLV | F4V
* Preset: FLV - Web Large, NTSC Source (Flash 8 and Higher)
Step 5
---* Same settings
After all this I keep the pixel quality high and the file size down.
Cheers
-=Jesse=-
