newbie
bill Cramer
newbie
on Aug 10, 2014 at 11:14:23 pm
I have ae 6.5,I have a layered psd file that I'm making space between the layers to create a 3-d look,when I pick a setting for output(ntsc-dv1)the file in the comp window becomes zoomed in to a just a small section of the original and will render out as such.I've different formats to the same result.Any advice.
John Cuevas
Re: newbie
on Aug 11, 2014 at 12:41:56 am
It sounds like your original image is much bigger than 720x486, so you need to scale down your psd file(s). Since you are offseting them to create a 3D look, I would go to Layer>New>Null. Nulls are layers that don't render, just used to control other layers. Move the null to the center of your psd image. Select all your .psds layers and parent them to the null, then just scale the null to your comp size.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Cuevas
Re: newbie
on Aug 11, 2014 at 12:44:01 am
Also if you are new to AE, I would strongly suggest you check out - Getting started with After Effects (CS4, CS5, CS5.5, CS6, & CC)
Thinkck.com
bill Cramer
Re: newbie
on Aug 11, 2014 at 4:08:47 pm
Thanks so much for your prompt reply,I'll use it,and thanks for the heads up on the training.Bill Cramer
