Text bounce scale animation by characters
Orkhan Huseynov
on Aug 12, 2014 at 8:37:26 am
How to do text animation like in this video?
It would be great to make a template animation for all text in comp, with expressions and possibility to set keyframes to start and stop.
https://vimeo.com/84591410
John Cuevas
Re: Text bounce scale animation by characters
on Aug 12, 2014 at 3:44:50 pm
You might want to try the free preset Amortype 2.0
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Orkhan Huseynov
on Aug 12, 2014 at 7:56:49 pm
Armotype is niceƧ but i can't set the start time and animate out. How to set start time, not from composition start?
John Cuevas
on Aug 12, 2014 at 4:23:17 pm
This might be easier---Here I just made 2 text animators, one scales up the text past what you want, the other brings it back down a bit. All you need to do is copy the first offset parameter into the second offset parameter and move it a couple of frames back.
7861_textovershoot.aep.zip
Thinkck.com
Orkhan Huseynov
on Aug 12, 2014 at 6:43:49 pm
You wanna say that to control the frame of start and stop, I need just set offset parameter in seconds?
John Cuevas
on Aug 12, 2014 at 8:49:02 pm
Are you using Amortype or the little project I made?
Thinkck.com
Orkhan Huseynov
on Aug 12, 2014 at 10:07:15 pm
Thank you for both solutions. I am using amortype, it's has soft bounce and more parameters. I couldn't set the inner and outer, but then I found it. Just crop text laver In timeline. Thanks, really helped.
