Can't export with Alpha
Jerel Peterson
on Aug 23, 2014 at 2:29:15 am
For some reason, I now have a computer that will no longer give me the option to export a quicktime file as RGB + Alpha -- that choice is grayed out no matter what project I open.
I've moved the project I need asap to a similar computer, and that one DOES give me RGB + Alpha. What could be causing this?
John Cuevas
Re: Can't export with Alpha
on Aug 23, 2014 at 12:42:37 pm
First what codec have you selected? Also it would be helpful to post a screen shot of the output module you have selected on the computer that is not giving your a RGBA choice.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jerel Peterson
on Aug 23, 2014 at 4:08:32 pm
Thanks for pointing it out -- for some reason, the codec was set for H264 instead of animation. It's working now.
