Placing text above a path
John Schneider
on Aug 24, 2014 at 4:57:11 pm
What happens is that when I set my text to a line, it always appears below the line and never above it. The "Reverse Path" function seems to do the trick but it leaves the text also appearing in reverse.
So how do I put my text above the path I created using the pen tool?
John Cuevas
Re: Placing text above a path
on Aug 24, 2014 at 9:15:21 pm
Can you post screen grab of your text and the text options, cause no matter what I do, I can't get my text to be reversed.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
John Cuevas
on Aug 25, 2014 at 12:02:04 am
Also, if the text is just below your path line, you could just add a position animator, and adjust the Y position.
Thinkck.com
