Can I change See-Through Tex to NON-See-through?
Jimmy Page III
on Jul 24, 2014 at 8:43:18 pm
Hello all! Thank you for reading this as I'm sure it's a dumb question:
It's a little hard to explain so I'll start from the top:
I downloaded a font that is block-text, like letterman jacket or something like that.
However, in After Effects, when put this text over the Video, the Font was revealed to be a stencil!
So the video plays through it and the font is essentially splines.
If i put the font over a white solid, THEN the face of the font looks correct (white) but then how can I make it stay this way (font-face filled in with white) while still having it over the video?
Is there a way in AE, either through Keying, or whathaveyou, to make it so the "Face" of the font stays white? Thanks so much!
I've been experimenting for hours and haven't found a solution.
John Cuevas
Re: Can I change See-Through Tex to NON-See-through?
on Jul 24, 2014 at 8:54:26 pm
Try using the paint bucket effect.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
