Slip Slide or Slide Edit Tool in AE
Lisa Ruiz
on Jan 12, 2015 at 11:57:00 pm
I'm looking to use the slide edit tool frame by frame with keyboard shortcuts. I have found this link that shows how to do it in Premiere Pro. Does anyone know if you can do this in After Effects with keyboard shortcuts? (I am aware of how to slide footage with my cursor only.)
http://www.premiumbeat.com/blog/premiere-pro-slip-slide-editing/
Thank you,
Lisa
Daniel Waldron
Re: Slip Slide or Slide Edit Tool in AE
on Jan 13, 2015 at 12:22:09 am
Hmm, well slip and slide edits are two different things. For a slip edit, In the timeline shorten your clip so that it is shorter than the timeline, then use the Pan Behind tool (Y) on the faded out bar of your clip. All keyframes, etc should remain in place while you slide the clip around. Hopefully that makes sense. I attached a photo that hopefully makes it clearer.
James Poulakos
on Jun 28, 2016 at 7:36:20 pm
Bless ye, ye done me good.
That was a great tip about using the Pan Behind (Y) tool to Slip Edit.
