DV output doesn't seem quite right.
Merrick Bahar
on May 3, 2010 at 5:46:10 pm
Is it true that After Effects does not handle DV natively?
Does this mean that any DV footage will show obvious degradation upon output? I am noticing this when re importing into my NLE (Grass Valley Canopus) and comparing original DV footage side by side with AE. I have tried various forms of export but no matter what the AE DV processed footage looks less sharp along with some slight motion issues.
Is there any way around this?
Dave LaRonde
Re: DV output doesn't seem quite right.
on May 3, 2010 at 7:48:54 pm
[Merrick Bahar] "Is it true that After Effects does not handle DV natively? "
That is incorrect. AE has troubles with HDV, not DV.
[Merrick Bahar] "Does this mean that any DV footage will show obvious degradation upon output?"
Not if you render in a lossless or uncompressed codec.
[Merrick Bahar] "...the AE DV processed footage looks less sharp along with some slight motion issues. "
Are you interpreting the footage and rendering in the proper field order?
Dave LaRonde
Sr. Promotion Producer
