Importing image sequence
Ron Craig
on Apr 28, 2010 at 3:34:41 am
For the life of me I can't remember how I did this before and a search here didn't turn up an answer. So I could use some help.
I want to import a series of still images to After Effects as an image sequence and I would like each still to have a duration of two frames. I know how to set the default still image duration in preferences and that works fine to import a single still image at a specified duration. But when I import a series of stills as a sequence, the system reverts to a duration of one frame per still.
I would really appreciate some advice on this. Thanks.
-- Ron
cowcowcowcowcow
Todd Kopriva
Re: Importing image sequence
on Apr 28, 2010 at 9:29:56 am
I think that you're looking for this:
"Change the frame rate of a sequence"
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Ron Craig
on Apr 28, 2010 at 2:12:24 pm
Thank you!!
- Ron
