Problems AE CS4
Jose Noguera
Problems AE CS4
on Apr 26, 2010 at 1:41:28 am
Hi
01 - I have problems with AE CS4 mts files to work with. Every time I use these files, The AE locks and I have to restart.
02 - another problem I have is screen control error igxprd32, To have this problem, The screen resolution setting of Windows deconfigured and xp AE asks me to save the project and restart the pc.
03 - I have problems also render projects. Specifically when the project has effects, The AE trying to process them or terminates locks not finish rendering.
This is the configuration of my pc.
Motherboard:
CPU Type DualCore Intel Pentium e5200, 2500 mhz (12.5 x 200)
Asrock motherboard name g965m-s (2 pci, 1 pci-e x1, 1 pci-e x16, 2 ddr2 dimm, Audio, Video, Lan)
Broadwater chipset intel G965 motherboard
1015 mb system memory (DDR2-533 DDR2 SDRAM)
DIMM3: Advanced Modular 1 GB DDR2-533 DDR2 SDRAM (5-4-4-12 @ 266 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 mhz)
BIOS Type AMI (05/12/1909)
Communication port communications port (com1)
Communication port ecp printer port (lpt1)
Monitor:
Video card intel (r) G965 Express chipset family (384 mb)
3d accelerator x3000 intel gma
Monitor monitor plug and play [nodb] (53916843009)
I think it is hardware problem, Because with the AE CS3 did not have these problems.
I hope I can help solve these problems, Thanks.
Dave LaRonde
Re: Problems AE CS4
on Apr 26, 2010 at 1:45:07 pm
Dave's Stock Answer #1:
If the footage you imported into AE is any kind of the following -- footage in an HDV acquisition codec, MPEG1, MPEG2, AVCHD, mp4, mts, m2t, H.261 or H.264 -- you need to convert it to a different codec.
These kinds of footage use temporal, or interframe compression. They have keyframes at regular intervals, containing complete frame information. However, the frames in between do NOT have complete information. Interframe codecs toss out duplicated information.
In order to maintain peak rendering efficiency, AE needs complete information for each and every frame. But because these kinds of footage contain only partial information, AE freaks out, resulting in a wide variety of problems.
Dave LaRonde
Sr. Promotion Producer
Jose Noguera
Re: Problems AE CS4
on Apr 26, 2010 at 2:03:41 pm
Hi, Thank you sir Dave LaRonde unanswered
As I understood I have to convert mts files to another type. Avi files can be eg?
Other codecs that I can use to AE not behave so no loss of quality and avoid making such large files?
Thank you again.
Dave LaRonde
Re: Problems AE CS4
on Apr 26, 2010 at 4:05:26 pm
[Jose Noguera] "Avi files can be eg? "
I would use a lossless AVI.
[Jose Noguera] "Other codecs that I can use to AE not behave so no loss of quality and avoid making such large files?"
When doing AE work, you need to get used to large file sizes. If necessary, get more storage.
Dave LaRonde
Jose Noguera
Re: Problems AE CS4
on Apr 26, 2010 at 10:04:43 pm
Thank you very much Dave LaRonde
Has helped me quite.
Greetings from Paraguay and good job.
