Any way to use Illustrator created artwork with Plexus2?
Juan Gordo
on Jun 24, 2014 at 4:32:24 pm
Hi
Sorry if this is a very obvious question but I only just acquired the plexus2 plug-in for a project and I can't figure out a way to use Illustrator created artwork with plexus, neither natively or converting it to shapes from the vector layer. Am I missing something?
Thanks in advance
John Cuevas
Re: Any way to use Illustrator created artwork with Plexus2?
on Jun 26, 2014 at 12:48:47 pm
You can select paths in illustrator, open AE, create a solid and paste. Then you can use the paths option in plexus.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Juan Gordo
on Jun 26, 2014 at 1:32:20 pm
Thanks, That worked perfectly.
John Cuevas
on Jun 26, 2014 at 2:51:34 pm
Glad to help.
Thinkck.com
