Twixtor : multiple same frame (already tried a lot of things)
Romain Bardinet
on Jan 13, 2015 at 5:49:11 pm
Hi guys,
Im totally new here, i read a lot of threads here, because i started editing on SonyVegasPro 11 one year ago. They were mostly really helpfull! Two weeks ago i turned to AE Cs6, and i really like this software, even if im not an editing god. So! I am using Twixtor 5.1.0 (not 5.1.5) and when i slow a track down, the twixtor make several times the same frame, then switch to the next one : like a simply time modifier, there isn't any created frame, so it gives something choppy :/
I rode a lot of forums, read a lot of topics, but nothing helped me :(
I may be blind xD
More informations : The clip i want to slow down is at 60fps, and it's the direct recorded file (60fps) from Fraps. + input frame rate put to 60fps
Twixtor seems to work perfectly on the same clip, just before the problem : Clip'sBegining-------Working Twixtor DESPITE ANIMATED SPEED------Freezing/duplicated frames------End of the clip.
For me it looks really randomn :/
And the only Twixtor setting that im changing here is speed.
Hope you guys will find something :p (as i said i tried many things, but you can give them again, we never know :s )
Im newbie pls dont kill me :x (+ sorry for fake name)
© 2018 All Rights Reserved
