Preview Is VERY VERY Slow And Stops
Anthony Uccello
on Apr 10, 2010 at 6:33:02 pm
Hi
I made a video of my problem
The preview goes really slow then stops.
Recently installed windows 7 64 bit running 4 gigs of ram.
Why is the preview going super slow then stopping?
Andy George
Re: Preview Is VERY VERY Slow And Stops
on Apr 12, 2010 at 6:02:00 pm
Hi Anthony,
The speed of your Ram Preview is really dependent upon what's happening in
your composition. It's hard to tell from your video exactly what's going
on in your comp but Im guessing it's got a lot of 3D layers and effects applied.
Can you provide some more details on your composition?
4 gigs of Ram is not going to buy you a very long preview. Especially in an HD composition.
Do you have "enable multiple Processors" selected? If so that may be slowing you down as well.
You don't have enough Ram to run more than 1 core at a time. Check out Todd Kopriva's
article on the subject-
http://blogs.adobe.com/toddkopriva/2009/12/performance-tip-dont-starve-yo.h...
-Andy
Jeffrey Kaplan
on Apr 12, 2010 at 7:09:30 pm
I noticed you want to preview the work in Full Res. Try setting your Comp window to 1/2 res or 1/3rd res and then hit 0 for a ram preview - you'll get a much longer clip.
Jeff Kaplan
Point 360 WEST
Animation & VFX Department
http://www.point360.com
Tony Brittan
on Apr 17, 2010 at 2:43:55 pm
Quick question about RAM preview...I'm new to AE and working on a Mac Pro with the Bluetooth keyboard. Problem is that the Apple Bluetooth keyboard doesn't have a numeric keypad. So...I can't use the 0 key for RAM previews. Can't I use the other 0?
Tony Brittan
Jeffrey Kaplan
on Apr 18, 2010 at 7:54:14 pm
For RAM Preview: there's a button in the preview panel that looks a little similar to a play button. See the following link:
http://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906...
Look under the "Use RAM preview to play video and audio" subhead.
You can also try a Standard Preview:
You can hit the spacebar for a standard preview - that will play the video in the active Composition, Layer, or Footage panel from the current time. However, Standard Preview will not play audio.
Jeff Kaplan
Point 360 WEST
http://www.point360west.com
Anthony Uccello
on Apr 18, 2010 at 8:52:06 pm
Thank you ALL
Im away until next week
Will address these points soon.
Thank you again
