AE keyframing problem - easy I'm sure
steve dann
on Mar 29, 2010 at 9:13:20 am
I'm keyframing a jpeg to move around the screen in STRAIGHT lines using linear (diamond shaped) keyframes. The path I'm getting however is curved with bezier handles. The smoother doesn't appear to be selectable, I'm baffled. Wasn't happening yesterday, can't work out what I've pressed. HELP!! Thanks.
Todd Kopriva
Re: AE keyframing problem - easy I'm sure
on Mar 29, 2010 at 4:10:45 pm
One thing to keep in mind is that there is temporal interpolation and spatial interpolation, and they're not related. If you have linear temporal interpolation and bezier spatial interpolation, you'll have the result that you describe.
Information on interpolation types and how to change them is here.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
