Import EPS/AI with each path as a layer
Matthew Beall
on Mar 26, 2010 at 1:57:07 pm
I have an EPS logo that I'd like to import into AE and have each path be an editable layer..
I've read the past posts about this and have tried all the suggestions.. I bring it into AI, select everything and use the 'Release to Layers' option. Then I make sure each path is on a layer by itself, like:
Layer 10
-Path
Layer 9
-Path
Layer 8
-Path
etc
I save as an AI 10 file with PDF compatibility..
But when I bring this into AE, it never gives me the option to keep editable layers (like it does with PDF files) plus it just rasterizes the logo into a single layer and nothing is editable at all..
What am I missing?
-Matthew
Todd Kopriva
Re: Import EPS/AI with each path as a layer
on Mar 26, 2010 at 3:35:53 pm
One thought is that your Illustrator document might be a CMYK document, not RGB. After Effects can convert CMYK to RGB, but it flattens/rasterizes the document when it does so.
There's more information here: "Preparing and importing Ilustrator files"
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
Matthew Beall
on Mar 26, 2010 at 4:20:45 pm
Todd,
Thank you for that link, it helps..
I didn't have the 'Preserve Paths' option checked in my options (I never use AI)..
All paths now layered with smooth/sharp lines in AE!
Thanks!!
-Matthew
