burst like soap bubble
Franzi Stodt
on Mar 9, 2010 at 12:43:39 pm
Hi does anybody know if there is an effect in after effects, that could let burst a video like a soap bubble?
i have two little videos, and as final i would like to let these two videos like a soap bubble.
for any help deeply thankful.
greets from germany
Michael Szalapski
Re: burst like soap bubble
on Mar 9, 2010 at 3:55:23 pm
Unless you're talking about slow motion, a real soap bubble basically just disappears. There will be a few little soap particles, but it really just goes POP and is gone.
However, I assume you mean you want it to blow up and disappear outwards. You could use a distort effect, such as Bulge. Coupled with Effect>Transition>Iris Wipe.
You'll need to adjust the parameters of the iris wipe to make it look round (make iris points a higher number), then feather it.
Assuming I assumed the effect you were after correctly, that should do the trick.
- The Great Szalam
Dave LaRonde
on Mar 9, 2010 at 3:58:27 pm
In addition to Michael's advice, you may also want to look at the Foam effect:
http://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103a9d...
Dave LaRonde
Sr. Promotion Producer
Bill Kelly
on Mar 9, 2010 at 10:32:59 pm
The Scatterize effect may also work for your situation. To make it look good, you would most likely want to introduce a blur on the scatterizing (is that really a word) layer as the scatterizing is taking place, and enable motion blur for the layer and the comp.
