copy over files to the other side of the comp
piff aroni
on Feb 24, 2010 at 3:51:24 am
say I have some video elements that I needed copied from on side of the comp to the other. I have some files in the beginning of a 10 second comp, what I need to to KEEP the files in the first 5 seconds but copy and paste them from 5 seconds on. how do I do this, I tried copy and paste but it just made copsies of the files and did not move them over
David Johnson
Re: copy over files to the other side of the comp
on Feb 24, 2010 at 12:39:50 pm
Just select the copied layers and drag them over to where you want them in the timeline. Or, precompose them and drag the precomp to where you want it in the timeline
Dave LaRonde
on Feb 24, 2010 at 4:15:16 pm
Y'know, it sounds like you'd get a LOT of good out of this:
http://blogs.adobe.com/toddkopriva/2010/01/getting-started-with-after-eff.h...
It doesn't get much better: a guy from Adobe scours the web for you to compile an excellent set of aids for the novice.
Read and explore EVERYTHING you find there.
Dave LaRonde
Sr. Promotion Producer
