enable open GL
dewan edwards
enable open GL
on Jan 28, 2010 at 8:01:43 am
Hi sorry for the basic question but I am not sure what is going on. I recently installed Quadro FX 380 to get a better open GL support. When I open AE and do to the display settings (I believe that is the one) Open GL is greyed out. It says that no supported hardware is found. Also in Avid I am told that my card is unsupported. Any ideas on what I am not setting right? Is there something in the Nvidia control panel that I need to adjust? Right now I am stomped on why my card is not being recognized for Open GL support.
system XP 32
CS3
Quadro FX 380
directx 9
display driver 6.14.11.8208
Todd Kopriva
Re: enable open GL
on Jan 28, 2010 at 4:11:31 pm
Here's a list of supported OpenGL cards:
http://www.adobe.com/products/aftereffects/opengl.html
I don't see your card on this list.
putting the 'T' back in 'RTFM' : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share---or if there is something that you'd like to see added or improved---please leave a comment.
dewan edwards
Re: enable open GL
on Jan 28, 2010 at 4:44:45 pm
Hi, the card I have replaced or is the newer verison of the quadro 370. I updated the driver and I was able to select the open GL. I Should have thought of that in the fist place. I havent been able to do any work yet to see if it runs smoothly yet. I will let you know if anything negative comes up. thank you
Joey Foreman
Re: enable open GL
on Jan 29, 2010 at 10:40:52 pm
Don't know if it's still Dave LaRonde's stock answer, but from everything I've heard, OpenGL doesn't work in AE, regardless of your card.
Todd Kopriva
Re: enable open GL
on Jan 29, 2010 at 10:59:44 pm
Dave overstates this issue.
I agree with Dave that you should never use OpenGL to render for final output.
I agree with Dave that you should probably not leave OpenGL rendering always on for previews.
_But_, the OpenGL - Interactive setting actually works quite nicely for making rendering faster during interactions---i.e., when you're dragging things around. The fidelity is poor, but that's OK when you're in the middle of dragging something across the screen; and the OpenGL renderer turns off as soon as you let go of the mouse.
Also, the GPU accelerates some effects behind the scenes.
So, while I agree with Dave and many others in saying that it's not worth spending a lot of money to get a top-notch graphics card for After Effects, I have to point out that there are some values in having at least a reasonable stock GPU with OpenGL features so that you can get these moderate-sized benefits.
dewan edwards
Re: enable open GL
on Jan 30, 2010 at 12:12:59 am
Ok thanks, I am removing this card anyway, I have been having some problems since I installed it. I researched some cards that my system suppose to support and that others are having succes with. thanks
