which rendering options
Hamid Rohi-Bilverdy
on Jan 22, 2010 at 8:36:22 pm
hi. What is the best rendering choose? I have a normal DV footage and when i render in RAM preview i get it all with sound, just as in my timeline. But if lossless i get no sound. I get with 48khz. How do i decide which is best for my project?
Dave LaRonde
Re: which rendering options
on Jan 22, 2010 at 8:47:47 pm
Normally, I don't even render with sound. If I have the video already edited in my editing application, I don't need it.
Dave LaRonde
Sr. Promotion Producer
Hamid Rohi-Bilverdy
on Jan 23, 2010 at 5:48:17 pm
So do you mean by that, that I can render with out no sound, and then e.g import my edited clip into premier pro? If i render something in AE and the output is without sound I should be able to put back the original sound on , by ripping the sound from the raw footage right?
regards Hamid
Dave LaRonde
on Jan 23, 2010 at 10:38:54 pm
You do it by REPLACING the original video with the rendered AE video. You should do this in a duplicated edit timeline in Premiere, in case you make a mistake.
If you do make a mistake, you will learn a lot by working backward to deduce the origin of the mistake.
Dave LaRonde
