can i remove only the words 'Based on' in 'Output Module' in Render Queue ?
wangji seo
on Jan 16, 2010 at 11:59:45 am
Hi, i'm a AE beginner.
This is my first posting and i really thank this site for good infos of AE.
I made custom template in Render Queue.
As you can see in captured image,
in 'Render Settings' there's no 'Based on' before my custom setting name.
But in 'Output Module', my custom setting name appears always with the words 'Based on'.
I've tried all the possibilities but in vain.
I know it is so trivial thing but i just want to know
if i can remove only the words 'Based on' in 'Output Module' in Render Queue.
Thanks for reading.
Dave LaRonde
Re: can i remove only the words 'Based on' in 'Output Module' in Render Queue ?
on Jan 16, 2010 at 5:22:33 pm
Make our own Output Module! If you don't know how, go to AE Help and use the search function using those words.
You can then set it as your default -- it tells you how -- and you're good to go.
Dave LaRonde
Sr. Promotion Producer
