Problem with Element 3D
Mehdi hb
on Jun 7, 2016 at 7:04:21 pm
Hey , i have a problem whe im using element 3D in after effect cc
the problem is that when a select a 3D object into the scene setup the grid is automaticly attached to this 3D object and whene im trying to move it the grid move with it and i cannot scale it
please help me
sorry btw for my bad english be cause im morrocan
Kalle Kannisto
Re: Problem with Element 3D
on Jun 8, 2016 at 5:23:28 pm
I suspect you don't have the scale tool selected. It is the fifth tool from the left with a small square inside and a bigger square.
Mehdi hb
on Jun 8, 2016 at 7:45:54 pm
no , ido click on the scale tool but when i click on it and i try to scale it , the object stays as he was
Mehdi hb
on Jun 8, 2016 at 10:55:20 pm
and when i click on a 3D object it make this :
http://postimg.org/image/h333m9y6j/
hanna dean
on Jun 9, 2016 at 12:03:23 am
element 3d depends on minimum gpu card, check your graphics driver.
you said you tried the scale but it dont scale remains as it is well , close it update gpu driver and try again, because each time u move object , resize the gpu is doing the work not the cpu , since its not updating with your scale the gpu is not working on that maybe.
Mehdi hb
on Jun 9, 2016 at 10:47:26 am
i will try i explain all in this video
hanna dean
on Jun 9, 2016 at 3:22:13 pm
Your using internal Graphics card if i am right.
get a seperate gpu borrow from friend try it.
hanna dean
on Jun 9, 2016 at 3:24:20 pm
on your video on the top right corner look close
on element 3d it shows
0 Mb Graphics memory GRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
your using built in internal graphics my friend you need a seperate graphics card.
hanna dean
on Jun 9, 2016 at 3:28:52 pm
Loook at my video it will help
Mehdi hb
on Jun 9, 2016 at 7:20:13 pm
oh ! well , i have 2 graphic cards
-Intel
-AMD radeons
i may used with AMD but i have some problem with OPEN GL so i unstall the AMD Driver and then it cause me this problem
i will redownload it now but i will have some problems with Open GL and i dont know how to fix it
hanna dean
on Jun 9, 2016 at 8:06:33 pm
well u need decent gpu , and to make sure its working on element 3d look on top right were it says video memory ram , that has to be read by element 3d.
as i have shown in my video look on top right my video memory ram , am not using internal graphics , i use seperate gpu.
so you do same , depending on your graphics card do research online ,get the drivers for it what is the model of it.
get that fix then your element 3d wil work
Mehdi hb
on Jun 9, 2016 at 8:18:35 pm
ok then i will try and inform you
Mehdi hb
on Jun 9, 2016 at 8:22:04 pm
but I don't really get the thing with the GPU
hanna dean
on Jun 9, 2016 at 3:29:27 pm
here is my video
check it
Mehdi hb
on Jun 9, 2016 at 11:53:28 pm
Oh ! i solved the problem by downloading the AMD graphic gard driver but i still have en top right 0 memorie
Mehdi hb
on Jun 9, 2016 at 11:55:09 pm
thank you so much for you'r help my freind
you really helped me a lot
hanna dean
on Jun 10, 2016 at 12:08:12 am
0 video ram
my friend you have not done what i told you.
read my top post , you need a new or second hand graphics card , a shitty internal graphics will not do the job the closest you get is the picture to load or maybe few frames , when it comes to adding effects your will will be on fire.
i assume you dont know what ( new gpu ) or new graphics card mean
look at picture
https://images-na.ssl-images-amazon.com/images/I/81sw0cdn9uL._SL1500_.jpg
https://i.ytimg.com/vi/YbGo335w5gw/maxresdefault.jpg
the graphics that is stuck on your motherboard is shitt full stop.
u need a graphics card ebay it , then you will se performance and no laggs , no fuzzy texture, no speed problems.
Thats the end of my reply and wil not reply no more sorry , if you need help just read from the very top post to bottom and understand good thanks.
