Track motion from coordinates using script
Abhipso Ghosh
on Jun 6, 2016 at 9:25:37 am
I have coordinates of the point from where the tracking should start. Now I need to have a automated way to start tracking the motion of that particular point.
For example if the starting point is (20,30) then the program should start tracking the motion from the script, not by manually dragging the tracker.
After that, I need the coordinates of all the points of the path through which the tracker moves. Until now I have done the coordinates extracting part, but it involves the manually dragging of the tracker part. What I want is : from only the starting point, the program will return me all the points of the path of object.
Thanks in advance.
