Blend this image in to remove outter line
hanna dean
on Jun 4, 2016 at 10:43:47 pm
Chris Wright
Re: Blend this image in to remove outter line
on Jun 5, 2016 at 12:01:44 am
maybe a mask with a feather
hanna dean
on Jun 5, 2016 at 12:05:41 am
it has a mask on it look also its feathered
Ocean Byrne
on Jun 5, 2016 at 4:59:08 am
I think your mask feather is too big? I'm guessing that square is the size of the layer, and you probably have a feather set to like 200, meaning it goes in 100 pixels towards the center of the mask to be fully opaque, and 100px out from the mask line to fully transparent. But once your mask gets 50 px out from the mask line the image ends, so there is nothing there to mask.
You could set the feather lower so it doesnt extend beyond the edges of your layer. You could try doing a repeatile effect on your layer to extend the edges, or you could find a way to pre comp or change your layer to make sure there is imagery occupying the entire composition, or at least all of the area you want it to be seen...
Greg Gesch
on Jun 5, 2016 at 2:18:43 am
Hi. Does it have anything to do with the layer being set to Screen mode?
hanna dean
on Jun 5, 2016 at 5:24:01 am
no the screen mode should not affect it at all.
also the mask is perfect and the feather is also perfect , the layer which has feather on has red colors on so u can se its red , its just the outter line not going away , normally a simple mask inside the body of object or layer does the trick with minor feathering , i done this but its not going away wieerd.
Walter Soyka
on Jun 6, 2016 at 6:24:44 pm
What is your mask mode? With Clouds 6 (top layer) selected, press MM (that's the M key, twice, quickly) to reveal mask properties. Share a screenshot of that.
Walter Soyka
