Combine Two Shots Together Into The Same Room
Collin Espin
on Jun 2, 2016 at 2:44:12 pm
I'm trying to combine two shots together with a blur and pan, to make it look as if they were shot in the same room. I'm fairly certain I've seen this done once before in AE, but I've searched and searched, and have found nothing. Thanks.
Dave LaRonde
Re: Combine Two Shots Together Into The Same Room
on Jun 2, 2016 at 4:03:36 pm
....and your question is what?
It's dead simple -- animate horizontal position, and crank up the motion blur. Depending on your shots, there may be chroma key or roto work involved.
Dave LaRonde
Promotion Producer
Walter Soyka
on Jun 2, 2016 at 4:23:27 pm
Are you trying to make a transition between the shots, or a new composited shot out of the two existing shots?
Screenshots will help you clarify.
Walter Soyka
