morphing and detail
Chuck Audicle
morphing and detail
on Jun 1, 2016 at 1:57:54 pm
Hello everyone,
Is there a possibility to morph only details of a photography?
I'm new to after effect and I only see full image morphing.
I would try to morph multiple building ,area ... of a city and keep the same environnement encompassing the morphing zone.
Also is it possible to integrate those morphing on a 360 panoramic export like photoshpere (and keep the virtual movement in them).
Thanks in advance for all your advices
Walter Soyka
Re: morphing and detail
on Jun 1, 2016 at 3:53:16 pm
I'm not fully clear on what you're trying to do, but just about anything is possible!
If you want to morph a foreground element without affecting its background, you'll need to separate the foreground from the background (probably by masking) and clean up the background in any areas where the changing foreground would reveal it (probably by cloning).
If you want to do it all inside a 360, you'll need to make sure you maintain the correct distortion and mind the seam.
Walter Soyka
Chuck Audicle
on Jun 1, 2016 at 4:59:24 pm
Hi Walter , and thank you for the quick answer !
I think you get what i wanted to do and i'll try with what you told me.
(it's like rotoscoping no?)
yet I'll try to be as clear as possible.
with multiple photograph of a cityscape, I want to create a 360 cylindric view (without zenith) where some elements from foreground to background (skyscraper,shop,river,bridge,...) are replaced at different moment using morphing by others, external elements.
Cordially
C.A
