Making an expression to link the value of One effect with that of another?
Ashley Gillespie
on Jun 1, 2016 at 10:42:55 am
Hi there,
First time poster but long time user of CreativeCow.
I'm looking for an expression to link the Value of a Fast Blur with the value of the 'Brush Size' on the Stroke Effect. For example I have animated the brush size of my stroke over time from 200 - 0 - back to 200. I would like the max value of the blur to be 50 (when the brush size is 200), and then to decrease as the stroke size does.
Ash
Kalle Kannisto
Re: Making an expression to link the value of One effect with that of another?
on Jun 1, 2016 at 2:24:27 pm
For Fast Blur Blurriness:
linear(effect("Stroke")("Brush Size"),0,200,0,50)
That is, if the effects are on the same layer. Also, in that case, you'll want to adjust the Stroke spacing down to something like 1% to make the result look smooth.
If the Fast Blur is on a different layer, you would pick whip the Brush Size from a different layer to replace "effect("Stroke")("Brush Size")" or add the layer reference in this fashion:
linear(thisComp.layer("The Other Layer Name Here").effect("Stroke")("Brush Size"),0,200,0,50)
