AE cutting off text on edges after rendering
Anne Bailey
on May 29, 2016 at 5:17:59 pm
Hi all,
I'm using a template to animate some text in AE, but every time I render/export, my .mov file has the text cut off. It doesn't look cut off in the AE composition itself, just after export (see images).
Any ideas?
Kalle Kannisto
Re: AE cutting off text on edges after rendering
on May 29, 2016 at 5:40:50 pm
The text looks squished in you comp view. I suspect you are not looking at it in the same view you are rendering. Does the Comp view say "Active Camera" at the top left corner?
