Human Spine Animation in AE
Ben Lewis
on May 27, 2016 at 4:14:39 pm
Hi, I've been asked about a job which would involve animating a graphic of a human spine and wondered if anyone could suggest a plugin that might help with the rigging/physics as it should move naturally to demonstrate how to correctly lift objects?
Basically an actor would act out the moves then on the right of the screen I want to animate the spine so it mimics what the actor is doing.
This is a great example of what I am trying to achieve but created in 3D.
Any help or tutorials would be greatly appreciated.
Kalle Kannisto
Re: Human Spine Animation in AE
on May 28, 2016 at 4:10:55 pm
If you're not rotating the spine in 3D, the puppet pin tool would probably work to bend a static spine image in a natural fashion. You can control the stiffness of different parts with the starch tool. The bones will distort slightly, but it might not be noticeable.
