Add all open comps to render queue SHORTCUT
alfredo bautista
on May 27, 2016 at 1:13:00 pm
Hello guys
I usually have to type some titles on different comps. When I'm finished, i have to manually add each comp to the render queue using the "cmd + ctrl +m shortcut" or the "cmd + shift + / shortcut".
But i was wondering if there's a shortcut or script that enables me to add all the comps to the queue at the same time without having to go one by one.
This is time consuming and it could also lead to some mistakes as you can easily skip one of them and don't notice.
Thanks in advance.
Alfredo Jair
Greg C Neumayer
Re: Add all open comps to render queue SHORTCUT
on May 30, 2016 at 5:51:58 pm
That sounds like a good case for someone to write a script.
But notwithstanding the other good solutions, I like to add an underscore to any of my top-level comps that I'll be rendering or at least dropping into a master comp. I also add the word "main" for the top level, if I only have one eventual output comp. This helps me identify them for rendering, as well as keeps them floated to the top of my Project Window for easy access when moving between main sections. Just a workflow idea.
e.g. : _MainProject, _Section1, _Section2 etc.
