Why do I get a quality loss after importing my video into after effects CC
Stephan Egli
on May 27, 2016 at 5:36:58 am
I noticed after exporting footage for the first time with after effects that the quality of the footage is a little less vibrant (washed out/whitish) compared to the original footage. I thought first it might be because of an effect I did, or the way I exported the video. But I saw that the footage looks worse the moment I import it into after effects. Even with 100% and full resolution.
Never the less I tried exporting it a few different ways hoping it would restore the footage. But nope. Btw the original footage is Quicktime MOV and I export it to that, same frame rate and everything. Also I tried it without any effects, just the plain footage. Nope. I therefor think that it must be the importing.
Is there any importing settings I should change? Anyone else experience this? Been searching online but can find many complaints like mine. I will say the quality difference isn't huge, but it is noticeable if you look for it.
Some info I would like to mention: I have windows 7, 16 Ram and I have the latest adobe software available. I have tried exporting both with and without the media encoder.
Walter Soyka
Re: Why do I get a quality loss after importing my video into after effects CC
on May 28, 2016 at 10:41:08 am
How are you comparing the videos? What codecs are you using?
Walter Soyka
Stephan Egli
on May 29, 2016 at 1:46:23 am
I open a video (original or exported version I have done both) in QuickTime, and then I take a snapshot of it, and then I compare it with the other video that I open in QuickTime. I know it isnt a snapshot issue. They looks the same. Also I can tell visually just by looking at the exported video that there is a quality loss.
I believe its H.264 HD1080p. That is the setting I picked in adobe encoder. Is that what you mean? And yes it is a 1080p video
