Solid Audio Spectrum
Ryan Ostroski
on May 25, 2016 at 10:07:00 pm
Hello! Is there any way that I can have solid audio spectrum without setting the audio bands to 2000? It really slows down the previews for me. I do also have Trapcode Soundkeys if there is something I can do with that. Thank you!
Kalle Kannisto
Re: Solid Audio Spectrum
on May 26, 2016 at 6:56:47 am
There's the Thickness control for the lines.
Ryan Ostroski
on May 26, 2016 at 6:59:11 am
Does that make the lines wider? I would like it in a smooth wave and not square.
Kalle Kannisto
on May 26, 2016 at 5:04:29 pm
It all depends on what you want the end result to look like.
For instance if you use 200 frequency bands with analog lines, Side A only, Duration Averaging with audio duration of 20 ms, you get pretty smooth lines. That's one side only and not filled. You can fill it in with another instance of Audio spectrum, if you set it to Digital. And then you can use a mirror effect if you want both sides.
No idea if that actually renders faster, but at least you have 200 frequency bands instead of 2000.
Ryan Ostroski
on May 27, 2016 at 2:00:02 am
I tried that but it does not look like the end result I want.
This is what I'm trying to aim for:
I'm not sure if I am doing it wrong but I currently have the audio bands set at 2000 for the look I want and it really slows me down.
